Old 04-16-2002, 05:45 PM
jcl79383 jcl79383 is offline
Default "All welding is NOT the same......."
mg. You aslo might want to consider that who ever welded your pipes maybe didn't do as good a job as they generally do. The sidepipe should be done in some type of jig. Pieces would not move that much, but.......If to much HEAT is put in a given area, things will warp. I make a product for sidepipes and went through 7 welders until I found one that understood metal. These things HAVE to be straight. If not you have to grind them. PITA. The one guy jumps around so not to place to much heat in one spot. The end results is a straight product. Just a thought. JCL
