Old 11-24-2014, 05:47 PM
talos talos is offline
Cobra Make, Engine: Everett Morrison/Side Oiler
Disconnect the line at the carb. Run the old fuel if the pump works into a container, until the pump runs dry, and the tank is empty. Add 5 gallons of non ethanol fuel into the empty tank. Repeat the process. Empty this fuel into a container. After everything is dry again, install a good fuel filter as close to the fuel tank as possible. Rebuild or disassemble the carb for flushing. Refill the tank with good non ethanol fuel. Re hook the fuel line to the carb. Start the pump and check for any leaks. (During this process work in a well ventilated area, clear of open electrical wiring, and a fire extinguisher near by). Sounds like a lot to do, but its not. Take your time, respect everything, and don't be nervous.
Tom
