  #22 (permalink)
Old 11-24-2014, 08:58 PM
lippy lippy is offline
Originally Posted by Tim7139 View Post
Remember, using the Right Stuff, ideally you need to get a feel for this . You do not want to keep screwing with it after application.
I tightened everything on the pan and left them overnight. About a week later, I just checked tightness and maybe 2 or 3 nuts snugged up a slight bit........then leave them alone unless something seeps.
But if I check them and they are all loose 1/8 of a turn, then I have to tighten them back to spec torque, right? That is what is happening. I checked the torque 4-5 times and each time they had loosened. I fear that if I just leave them I will develop leaks.
