  #26 (permalink)
Old 11-25-2014, 06:20 PM
Tim7139's Avatar
Tim7139 Tim7139 is offline
Cobra Make, Engine: Superformance #2660, FE-406
Originally Posted by lippy View Post
The studs were new and clean. I used Permetex Hi-Tack between the gaskets and windage tray, and then a bead of Right Stuff between the gasket/pan, and gasket/block, probably about an 1/8" bead, and around all bolt holes. I can get a torque wrench on all the studs but one, and tightened to 90 in-lb, which is 7.5 ft-lb. That *should* be good, and I don't want to distort the pan. Do you think I need a bit more torque?
I use Right Stuff silver on all surfaces.
The older I get, the faster I was.
