Old 11-26-2014, 07:07 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Thanks Talos.
Good advice. I worry about pounding my nice SW fuel pumps to do all the work though.
Not a problem. That's what they're designed to do. They run all the time when you're driving. Just disconnect the line at a convenient spot, and connect a longer line that will lead into a fuel jug.
Then ground out the fuel pump relay using a dead-man type of arrangement. 20 gallons of fuel is a lot, so you'll need plenty of fuel jugs.
If you're worried about fumes, open the garage door and turn a fan on. The fumes are heavier than air, and will flow like water.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
