Old 11-27-2014, 08:55 AM
Three Peaks Three Peaks is offline
Originally Posted by ScratchBuilder View Post
Thanks to the CC member who pointed out that Acton Custom had installed the rear springs on the front of the car:
And the front springs on the rear:
You can also see the rubber bumper on the shock in the wrong spot.
SB
May or may not be true. With my QA1 springs, that is how they are mounted also due to the fact the springs for the rate I was seeking are only available in certain lengths. Those springs are probably mounted in the correct position if you check the spring ratings.
However, Jamo has made a great suggestion and I hope those involved take heed of it. Thanks Jamo.
Bob
