Old 04-16-2002, 07:23 PM
Cal Metal Cal Metal is offline
Original Shelby Owner
It sounds as though the top gasket must be shot and the fuel is seeping into the accel rod hole, although that opening has a slightly raised brass sleeve. In addition to the top gasket, check and make sure you don't have a bad needle/seat, as it would take a real high float setting, coupled with a bad gasket, for gas to seep down that rod bore.
Aggie:
How are things since the float height was raised to .190. Let me know. thanks.
