Old 11-27-2014, 04:16 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
The factory bleed nipple setup is rubbish in my opinion. Difficult to use as you cant easily clip a bleeder hose onto it to stop air going back into the system.
A remote bleeder setup makes life easier.
If the system is brand new you may also need to bench bleed the MC to get any air out of it.
I used 7/8" Wilwood MC. Wilwood High-Performance Disc Brakes - MasterCylinder No: 260-3376
One of the things I like about them is there is a bleed nipple on the MC that makes it easier to get air out of the system since the bleed nipple is at the highest point in the whole setup.
A #4 line is also a must since the #3 line will not flow enough to let the clutch engage quickly enough and clutch slip will result.
My system proved to be dead easy to bleed once setup
Mike Murphy
Melbourne Australia
