  #22 (permalink)
Old 11-28-2014, 08:12 AM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Hey Zedn
sounds like you have air in you MC.
Try bleeding from the line fitting that connects to the end of MC.
Just crack fitting open while bleeding and bubble should disburse.
Once all air (bubbles) removed from master cylinder then move to slave cylinder and bleed from there.
Had same problem on mine and found this to be only way to remove air from Master cylinder
