Old 04-16-2002, 09:14 PM
sfry's Avatar
sfry sfry is offline
Cobra Make, Engine: EX- Owner/Builder of a Hi-Tech & CSX4264-Southern Automotive 427 Side Oiler,Now I am sitting on the porch!!!
Send a message via AIM to sfry Send a message via Yahoo to sfry
Roger,
This will take a couple of threads.
If the body is in raw gel coat you should first wash it with soap and water and then wipe it down with a product made by Dupont called 2319S. This will help in removing any mold release(waxes) from the factory. DO NOT USE ANY SOLVENT BASED CLEANERS!!! This will create static electricity and could ignite!!
Next, Sand the body with 120G on a DA to open the pores of the fiberglass.
Then, Do bodywork:finishing your bondo in 180G or finer.
Now you will be ready for a high build Urethane primer.
After lots of block sanding and re-priming you should be ready for the Base/clear part.
Let me know if you have any more questions. I am a Senior Technical Rep for the largest automotive paint supplier in the world. And I have painted cars since I was 10.
Shannon
