Old 12-04-2014, 06:04 PM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
Originally Posted by scottj View Post
I'm not following how height-adjustable mounts isolate ride height changes from corner weight changes. ??
Let me first say that I am not a suspension expert by any stretch of the imagination. But, what I said was, this enables me to adjust ride height independent of spring preload, not independent of corner weight. I initially decided to make new rear shock mounts just because the SPF mounts seem to have some history of failure, so I decided why not build some adjustability into them at the same time. The stock SPF mounts can actually be adjusted for ride height by moving them up or down to another bolt hole, but these adjustments are in one inch increments.
I have read many (maybe all) of the posts on this forum concerning suspension set-up. I have read where people have adjusted ride height and had corner weight adjustments made, both by adjusting spring preload. It doesn't seem to me that it's possible to accomplish both of these things by making the same component adjustment.
I will try to post some photos of the shock mounts.
Ted
