Old 12-05-2014, 01:09 PM
blykins blykins is offline
Tremec transmissions suffer from tolerance variations, just like every other manufactured part.
They usually shift pretty good up until about 6000, then they need some lovin'.
If you're used to a T5, T45, or Toploader, then you're outta luck...hahaha
The factory shifter is pretty lacking. The aftermarket shifters are shorter throw, with a more firm movement. They also have adjustable stops.
An aftermarket shifter will improve your trans a bit, but if you're trying to shift it quickly above 6000, then we offer internal upgrades for that.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
