I started with a TKO and bought a aftermarket shifter which made a little differents. When I had 12,000 miles on it I sold it and bought a TKO600.
I have about 30,000 miles on the TKO 600. It was hard to shift when new. Got better when I had about 5,000 miles on it. But when I try to shift fast from 2nd to 3th I would miss 3th. Sometime last year it got so bad that I contacted Liberty Gears. They did a street upgrade for a little over $300.
I love it! Can not miss third even if I'm trying. If I buy a TKO it will have the street upgrade before I put it into a car.
When I say "fast shift" I mean I let off the gas and I use the clutch to shift.
Before I had to shift to 5th in a H pattern, now I just push the shifter a little to the right and forward. I never miss 5th. Fast and easy.
Yep I like this trannie.
It took us 1/2 to tear down the trannie and 2 hrs to put it together.
Dwight
below is the email from Liberty Gears;
Hello,
I prepared a list of what needs to be sent back as well as what we need to complete your surface enhancements.
Returns: 1st Gear (missing stops)
2nd Gear
3rd Gear
4th F/P Cone
Top Cover Complete (3/4 fork and rail mod)
½ & ¾ Faceplate Sliders
Parts to Upgrade: Stock ½ & ¾ Hubs
Stock ½ & ¾ Sliders
4th Syncro Cone
We are replacing your 1st through 3rd Gears, replacing the ¾ Fork and Rail, and then metal enhancements on gears, syncro’s, hubs and sliders.
If you have questions or comments please feel free to contact me by replying to this message or calling. I believe we will be sending you a return label as well to cover freight, you should receive it within a day.
Thank you,
