Old 04-17-2002, 06:16 AM
COBRA9268 COBRA9268 is offline
Default AOD QUESTIONS
Hey , the aod is an excellant way to go in a FFR or any cobra for that matter. Im running one in my car, with a supercharged 306 built to 495 hp, and very happy with it. Trans is based on a lentech and lock-up set up. The converter is a lock-up 3500 stall and 4.10 gears on an aurburn. There are many reasons for this setup so first the trans. Get a stock aod and have it gone through by a good reliable person who knows the upgrades, like the better cluthes and the bigger OD band and so on, much less expensive than a lentech complete, but you will need there valvebody (375.00) and a good converter (450.00-500.00) TCI makes an awesom converter, comp lockup 3500 (jegs). From there you can get a shifter. The reason for the lockup is that 1 and 2 are non lockup and 3,4 are lockup. The car onyl weighs 2200 lbs so it can have the best of both worlds. The lockup runs cooler and in third gear i can cruse at 3000- 3500 rpm with the converter locked up and the power band is awesom. 1 and 2 will come on like a rocket and by the time you hit third at 6000 the lockup will not affect the torque bad enough to dissapoint you. Once on the e way or good strech of road the O/D can be used at crusing speed. Im at 3000 rpm at 80 mph, at mpg. OD is not a gear that can be wide open throttle, it is a cruser only. The gear ratio can be 3.73 or 3.55 but no lower cause the converter needs some help. Lower converter lower stall, everything must go together..... Also needs a trans cooler in the nose. Good luck, ive had 3 combos in my car to get it right, please dont make the same mistakes i have, very costly, and remember, 2200 lbs dosent put much strain on a trans.........
