Old 12-08-2014, 02:49 AM
Default Check pinion play
Stephan427sc Check the pinion play on the diff. If you are doing hard accell and downshifts, you may have loosen the pinion bearing and caused a leak. Dana parts , you can get anywhere. Jag parts, Jeep parts, or any auto store. You need the seal # stamped on the seal to match up. There is about 4-6 different designed seals for the same rearend case. It might be simple to just call Dave and ask for them to send a seal. R&R is a little more intents to do. When you get the seal, make sure it slides on the pinion and seals. Do you have air tools and a puller to do this job?? It's simple to do, takes too much time to type. Leave a number to call you at and will walk you through this. Seals don't just start leaking by themself's. Try Morris repair on breather system and make sure this is fixed before we tackle replacing the seal. Rick L.
