Old 12-08-2014, 08:25 AM
redmt redmt is offline
Originally Posted by Morris View Post
redmt
Thanks for the kind words.....and hope that will help others when they get into situations they don't understand ...
Stephan
Two quick thoughts come to mind.....yes, even though the brake reservoir is vented....it is. Not vented enough......so yes a different catch can that can breath a higher volume of air would be good......also check your fill level.....many Kirkhams used a Dana Rear end cover that was a front diff cover on a Jeep.....and the fill hole is to high for the level of oil....lower the level of oil to the line I show in my photo's......I think it's about the middle of the lower cap bolt.....
The fence we built into the cover works especially at high speed usage....many laps at Road America.....
Morris, It's us that should thank you for the thousands of hours of R&D and the hundreds of hours of documentation with clear explanations and pix to boot. Passing on education is the most valuable commodity we have.
