Old 12-10-2014, 03:11 PM
DanEC's Avatar
DanEC DanEC is offline
Remember I explained to you how to check the voltage drop over your trailer relay? And that it was possibly eating up way too much?
Yes, and I've already changed out the trailer relay unit once and not in a mood to do it again. The 2357 bulbs are an improvement although not as good as the LEDs.
If the voltage drop across my trailer relay is too great (?) then there is a good chance it could be too great over Large Arbor's relay also. His car is closer to yours which are older than mine - maybe there is a problem with the newer trailer relays.
Yes, the turn signal flasher and brake light element worked fine on my ERA flasher - just no tail lights.
ERA 782 Running
