  #40 (permalink)
Old 12-11-2014, 06:01 AM
strictlypersonl strictlypersonl is offline
Yes, and I've already changed out the trailer relay unit once and not in a mood to do it again. The 2357 bulbs are an improvement although not as good as the LEDs.
Yes, the turn signal flasher and brake light element worked fine on my ERA flasher - just no tail lights.
Tail lights (parking lights, I hope) are completely separate from the brake/signal circuit, including the relay board. You must trace the red wire from the back to the connection at the driver's footbox to the fusebox, where the front and rear connections split.
