Old 12-11-2014, 09:19 AM
strictlypersonl strictlypersonl is offline
Bob - to recap the earlier part of the thread - my tail lights and turn signals and brake lights all work fine with standard bulbs.
Installed the LED bulbs and the turn signal lights and brake lights work but the tail lights no longer lit up when lights are turned on.
Disconnected the lead at the tail lights for the turn signal and brake light circuit and then the tail lights worked (lit up) when lights turned on. Reconnect leads at tail light bulb holder for turn signal and brake lights and tail lights went off again.
Reversed leads on tail light bulb holder and tail lights worked OK with lights on (but burning on brighter bulb filitment). Turn signals and brake lights didn't work.
But to be clear - everything works just fine with 1157 or 2357 bulbs used.
Dan
If the the lights worked with standard bulbs, but not with the LEDs, the only conclusion I come up with is there is something wrong with the bulbs or their connections. Have you tried testing the bulbs when they are not in the socket?
