Thread: Steering damper
Old 12-12-2014, 11:55 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Front suspension on my Contemporary is Jaguar XJ6, which is not known for bump steer generally.
But with wide tires in front 245/60-15 that is probably another matter.
I have seen that bump steer kits are offered , which basically relocate the steering link bar higher or lower on the ball joint, so as to be as parallell to the lower A-arm as possible. I have not checked my setup, but will have a look. Maybe that is the problem.
If not,since bump steer happens only on large bumps or potholes, I wiil have to install a damper somewhere.
Nothing sounds better than a Cobra in a Tunnel !
