Old 12-12-2014, 01:21 PM
Donunder's Avatar
Donunder Donunder is offline
Originally Posted by 07cob View Post
I have mine in front of the passenger's footwell. Access is a little tricky - I have cut a panel in the FR wheel arch and need to remove the FR wheel to change the battery. It fills the space nicely.
Geof I'm a bit confused here.
Wheels are usually referred to as LF RF LR and RR. The passenger's side front wheel would be LF but have you actually mounted the battery in front of the footwell where your sidepipes would normally sit or have you cut into the front of the footwell a little to accommodate the battery? You're not worried about heat from the pipes affecting the battery down there? No clearance problems on full left lock?
Any chance of a photo?
Don.
