Same as Wazza only passenger side.
I run #3 earth cable directly to the block and also to the chassis and a #3 positive cable direct to the starter both tucked up in the transmission tunnel.
I was told to give high priority to really good earths, don't rely on just an earth connection to the chassis, it can cause all sorts of gremlins to ECU and other electrical components.
I had a tray made up that bolts thru the fibreglass then brackets to hold the battery tight. Triple check this as my battery got loose on the track and now there's a couple of nice stars in the guard :-(
I think I'm not the first to have this happen!
Greg
