Old 12-12-2014, 07:27 PM
poboy427 poboy427 is offline
Cobra Make, Engine: SPF #373,Shelby FE Alum Block #077, 488 stroker, Tunnel Port, Dual-TMP DP Holleys
Default plumbing a PCV using a TP C7OE-9425-A intake
I'm setting up a elect vacuum pump to handle the brake vacuum needs on my Tunnel Port SPF Cobra. Apart from that my other vacuum requirement is a planned pcv system.
I would like to run a pcv but unsure about pcv options. I can plug a pcv into a valve cover and run a breather on the opposite side VC or I can put a pcv into the block off plate at the back of the intake.
This TP 2x4 intake has an equalizer tube cast between the 2 carb plenums. If I plumb the pcv into one of the two ports (R or L side) situated within this equalizer area of the intake beneath the carb bases. Will that be acceptable?
I would like to run the pcv out of the back of the intake draft tube plate because it is a cleaner look though it may be more efficient on the valve cover. Any thoughts on that welcome too.
Thanks Ray
