Old 12-14-2014, 05:04 AM
DanEC's Avatar
DanEC DanEC is offline
Thanks Rick - car only has a few hundred miles on it so I think I will try changing the brake pads. I think the rotors are fine and there is absolutely no pulsating through the brakes when applied. Wheel bearings were all all pressure lubed, torqued to seat, backed off and re-torqued to 15 inch-lbs so should be good. I'll try the CRC stuff to as I think I just used some high-temp RTV when I assembled it.
ERA 782 Running
