Old 12-16-2014, 04:44 AM
Modena's Avatar
Modena Modena is offline
Default Evans waterless coolant
Is anyone running Evans waterless coolant? I've been reading up a bit, sounds like it might be worth a try, no water so no corrosion and no electrolysis, boils at 190C, you can run a 7lb cap which releases strain on hoses etc, and apparently works better than regular options particularly inside the heads.
I can't seem to find any bad reports about it, other than nay-sayers who haven't actually tried it.
It also lasts forever (20 years), the only downside appears to be cost, $90 for 4 litres so a full system is over $250. If you are flushing an existing coolant you need their water absorber product too which would add more cost. My system is obviously new and dry so I would only need the waterless coolant.
Is anyone running this?
Ben in AU
