  #39 (permalink)
Old 12-16-2014, 03:17 PM
Ohio Ken Ohio Ken is offline
Cobra Make, Engine: Classic427 351w
Originally Posted by MaSnaka View Post
Ken,
I just looked at how my brakelines are held in place. I don't recall anything complicated or requiring modifications with the parts provided. The frame member where the OEM brakelines were held has a 3/4" hole, there is a square "C" clip that holds the line fitting in tight on the inside of the frame and the outside of the frame there is a hex nut on the flex line that fits against the hole in the frame. If you PM me your email I can send you a pic of the inside and the outside of the frame member. Hope that helps and I'll keep an eye on my PM's incase you want the pics. Good luck.
John
Thanks John
Sounds exactly like mine. But with the 3/4" hole, I did not like the way the outside hex fits, (where the very tips of the hex is the only thing holding).
I found my own solution, by taking two fender washers and cutting a hex shape in the ID using a dremel tool. Then welded the washer over the hex on the fitting. Now can't slip into the large hole!
Thanks
Ken
