Old 12-18-2014, 06:19 AM
DanEC's Avatar
DanEC DanEC is offline
I'm not sure the seal failure is a symptom unique of the inboard brakes - I may be wrong. Both rear suspension set ups utilize rebuilt parts and sourced parts and fabricated parts and on occassion things just fail - stuff happens. This is not criticism of ERA - their design and engineering of the chassis/suspension in this car is second to none.
You can probably scan over the history of posts under the ERA section and find several rear seal and rear bearing failures invovling the rebuilt differentials and I think they will be shot gunned across both the original and ERA rear suspension systems. That said, if you do your own work, access to the outboard brakes for bleeding and maintenance is much better. I can bleed my inboard brakes from under the car after installing speed bleeder units but a change of pads will involve pulling the seats and rear differential cover panel. It is much easier to just pull a wheel.
If the extra $700 or what ever (I thought it was more) is not that significant in you overall budget then it's really not an agonizing decision. For most of us that built with the standard Jag suspension, we either just couldn't afford to check every last option box or also in my case, I wanted to run undercar 2-1/2 inch tailpipes for exhaust.
ERA 782 Running
