Thread: Raditor mount
Old 12-18-2014, 11:41 AM
raider390 raider390 is offline
Cobra Make, Engine: LSC427
Thanks for the info... Barnsnake that is exactly what I am running into, I guess I will cut the bottom outlet and weld it higher and with an elbo.
Dwight how do you have that upper bracket mounted? That is the other issue, securely mounting it in place. When I got the car the radiator just sat in the lower mounts and had small side braces that were useless, it just flopped around!
Thanks for the replies.
