Thread: Raditor mount
Old 12-18-2014, 10:20 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
I don't have any good pictures of my installed radiator mounts, but I think I can describe them. They lower mounts are basically small sections of channel that I shimmed with pieces of 1/8" thick medium-hard rubber until the lower portion of the radiator is a tight fit into them. Their height in the car is set by a piece of steel tubing and shim washers on their mounting bolts. The side mounts are similar sections of channel that are shimmed with rubber to be a good fit on the side tanks of the radiator. (I'll put a picture of them in my gallery.) The tabs that mount them to the frame are not quite parallel with the frame, so when they bolt down it twists them a bit against the radiator. This makes them hold quite securely. I'm not sure you could pull the radiator with a hoist. Even so, I added a couple of aluminum straps from the top of the radiator down to the side mounts to ensure the radiator stays down solidly against the bottom mounts.
Jim
A Gnat! Quick, get a sledgehammer!
