Old 12-19-2014, 05:27 PM
SydneyChris SydneyChris is offline
Default dual radiator fans
I was looking a dual fan set up for the radiator, mainly to cut down noise from the apparently rather noisy single 16" fan that comes with the FFR Coupe kit.
The only specs I have seen on a 16" fan indicate between 1500 to 1750 CFM, with a dual 12" unit displacing 1600 CFM.
Appreciate any experience with relative noise levels and whether a dual 12" set up pulling 1600 CFM (through an ac condensor coil as well) will be sufficient to meet the cooling requirements of the Coupe.
With thanks
Chris
