Old 12-23-2014, 10:38 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
A couple things: what will you connect the rear brace to inside the trunk? Will it line up with the chassis? You will probably need to drop the fuel tank to make some kind of mount back there to attach it. The new leg mount will create an issue with carrying your top and side screens in the trunk. The original opening in the body that you need to cover has had the battery cut off switch located there and looked quite nice with the right plate to cover the hole. Plate painted body color looked nice. Will it clear the trunk hinge?
Blas
SPFWiringDiagrams@Comcast.net
