Thread: I'm an idiot
Old 12-25-2014, 07:42 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Scuff up the patch and the surface it's being applied to with some fairly heavy grit sand paper first so the adhesive has some "tooth" to grab on to.
Make sure both surfaces are as clean as possible before doing the adhesive thing. Try some brake cleaner. It evaporates fast and doesn't leave residue.
Just consider it as adding another skill to your set. I add skills about once a week.
DonC
