Tom- thanks for your thoughts.in regard to rear brake bias and lock up,I only did that briefly for isolating the issue.brakes are back to where they should be,front locks first.
As for the handbrake test,I'm pretty sure I did that a long time ago. I don't really see the relevance as the two are independent and it only does it with foot pedal pressure.its also intermittent.very hard to repeat consistently. But the handbrake pads do keep wearing? I have return springs on the arms now,but maybe not enough.i keep having to adjust them?
Rotors are centred.
I'm going to bleed them again this weekend and see if that helps.i will be looking into the ebc Reds soon.
Cobra3170- interesting,that's kindof what the brake guy was saying.im not sure if the sensation you had was pulsating due to material build up or more like mine and being a high pitch chatter.i don't get any pedal feedback.
But another thing to look into all the same.
I did record it yesterday but too much background noise was picked up.will try again today.
Ok.thanks guys.
Reason: More info
