Old 12-26-2014, 11:20 AM
Phill Pollard Phill Pollard is offline
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
Originally Posted by lippy View Post
I have 12 AN lines going from the block to my remote oil filter housing, and I just use the right adapters (I think they are NPT to -12 male). You could do something similar with your oil cooler. BTW, I have an oil cooler, but it is capped and not used because I want to keep my oil temp up. I might hook it up if I track the car, but not for the street.
I have a ERA too (#446) and it has a clear plexi plate in front of the cooler so no air flows through it. It looks 'factory' but one of the previous owners could have installed it.
I know from experience with motorcycles that the 'rule of thumb' is, if YOU need a jacket, the oil cooler needs a jacket. If you DON'T need a jacket, the oil cooler doesn't either.
So on the hot summer days we have here in CO, I plan to remove the shield. It has 4 small velcro pads on the corners of it so it appears to be made to be easily removed.
Phill Pollard - Co. Springs, CO
ERA 427 S/C (427FE SO)
