Old 12-30-2014, 10:41 AM
ollykiwi3 ollykiwi3 is offline
Couldn't duplicate the issue on the hoist.
Got the brakes hot but doesn't seem to have enough load on the system to create the same problem.
Went out the driveway and one minute later it was chattering.
It's defineatly worse with the balance bar biased to front which gives better front lock up.
I'm going to look into brake line pressures at light pedal load.i have .7"for front and 5/8 for rear . Might swap them over just to see the difference. They are small but I have small pedal ratio 4:1. They work fine you just have to be working a bit harder.
