Old 12-30-2014, 05:39 PM
strictlypersonl strictlypersonl is offline
I haven't had a chance to check out the Wilwood specs. Previously, I've found that ssbrakes.com had an equivalent 2-piston aluminum caliper that would directly substitute for the GM. (A185S) That exact part number isn't listed anymore. I'll have to do some calculations to match the piston area of their (and Wilwood's) current offerings.
*Calcs done. 2x43mm pistons almost exactly matches the area of 1x2.375". If the Wilwoods have a similar piston size, they should work OK without changing the master cylinder.
