Old 12-30-2014, 06:43 PM
patrickt patrickt is offline
Originally Posted by sea2jet View Post
I would say that would be a good upgrade. Patrickt, how is the ERA rollbar mounted? I'm a bit worried if it's also a slip fit. If so, I want to modify it to make sure it's properly fastened with good quality hardware.
There is a large heavy sleeve welded on top of the frame. The roll bar ends slip in to that sleeve so they are resting on the frame. A bolt then goes through the sleeve and the bar. The trunk brace is a little different.
Originally Posted by Dimis View Post
Patrick. Does ERA have you on commission?
They should!
No, but they should.
If you want it now! Get an SPF!
If your happy to wait then put the deposit down and join the queue.
Yep, the year they took building my car seemed like it lasted forever. But in the end it was worth it.
