Old 12-30-2014, 07:07 PM
DanEC's Avatar
DanEC DanEC is offline
Good post - I've actually managed to knock several of mine out already but here is the whole list.
- Pull tailpipes to repaint and pass side collector to re-seal due to exhaust leak (all pulled off so far)
- Crank rear ride height up 1/4 inch (done)
- Extend rear suspension trailing arms 1/4 inch to fix rubbing at front of wheel wells. Touch up rubbed off undercoating on front closure (done)
- Pull front brake pads and sand to remove any glaze. Scuff up rotors with sandpaper to break up glaze (done)
- Pull valve covers and adjust hydraulic lifter preload (remains)
That's about it.
ERA 782 Running
