Old 12-31-2014, 11:22 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by CHANMADD View Post
Why don't you grind the end of the rod down ...drill a hole through it and then, a washer, and split pin.........problem solved ......a little light grease there too....��
That would work if his tuning is already correct.
The factory adjustment nut is for total fuel volume throughout throttle travel.
The owners real problem is, that he needs to have this style of IDF:
http://forums.pelicanparts.com/porsc...nock-offs.html
Gary
