Old 01-02-2015, 06:52 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
I use Playdough. I put it inside a plastic bag and place it onto the pickup. Install pan. Or just pressure the pan down real hard.
Remove pan, very carefully remove Playdough from bag, take a razor blade and cut thru the center of the Playdough. Then measure.
Dwight
make sure the pickup is parallel with the pan. You don't want one side of the pickup higher than the other. Crooked!
