I use Torque Pro (Android) which has a free 'Lite' version with some restrictions. You'll only see the generic codes but that could be enough to pinpoint the issue.
I had a problem with my L98 not firing due to voltage drop through the ignition barrel when cranking. Do you have a dedicated relay for the starter? You need a bit more than 12v to the ECU when turning it over, if I remember correctly.
"A spectacularly fast car in a grand if dated tradition."
