Old 01-06-2015, 11:41 AM
Default Great tire when new and soft
Detroit Bill Bill you will have to check and make sure your cobra has the clearance. My old car is serial# 428 and had to get some rear body work to clear the 335, 35 r 17" Pilot tires where great for a couple of years. Car handled like on rails. Had to up the springs to a higher # 450 and changed the shocks to QA1's. Once this was done, no rubbing on the body of the car. I used these tires for 7 years, kept them covered in the dark and used VHT to keep soft. After so many heat cycles of the tires, they get hard and loss some of the grip. I do 95% track running and 5% street. My area has potholes that tanks disappear into and not return. Also have high sewer covers. Good thing is they don't pickup alot of crap off the road. For street would get again if you can still get this size.
Nitto 05. great tire once it is warned up. Only down side is picking up every piece of carp on the track or road. Have a 200 wear and is still soft after 6 autocross and 2 track cruises. They come in a 315 size. They are street legal but wouldn't want to get caught in the rain or wet roads.
Side note for either tire, to pervent flat spots I keep the car off the ground. Have jack stands under the "A" arms front and rear. This saves driving on square tires until they warn up and have to rebalance them after racing. Make sure you have full lock to lock with steering and not rub the body of the car front or rear areas. I have about 1.5" of travel up and down and 2.0" in the rearend. Softer setting in rearend of car to get better traction. Also have sway bars front and back from ERA with solid bushing of hard plastic donuts from PST suspension. Have hard plastic on all bushing in the suspension arms. I did modify them with adding grease holes in the arms and grooves in the bushing to lube. Running the same bushing for 15+ years and suspension is still tight. Good luck with your car. Rick L.
