Thread: Cammer parts.
Old 01-07-2015, 07:41 PM
mhacars mhacars is offline
I feel that if someone got burnt by a vendor then they should make it known so that others are weary and do not have the same experience. I had my Cammer built and it was broken before it was even installed in the car. If you search my posts, you will see what I went through.
I went through a lot of aggravation collecting all the parts and having some specially made and the vendor I entrusted everything to ruined it. Jim Barillaro is someone who is dishonest in the way he did not take responsibility for what happened and although he promised to compensate me financially, he has disappeared. Once that motor was taken apart, it was clear that Barillaro is not qualified to machine or assemble a quality motor.
As a result, I had to start over at great expense and I was extremely fortunate that Ernie Elliott was willing to investigate why it failed and make it right. By the way, I originally had a gear drive in mine installed by Barillaro and Ernie Elliott went back to the chain. He felt that if set up properly, the chain would be fine.
