Old 01-09-2015, 08:50 PM
Grey 65's Avatar
Grey 65 Grey 65 is offline
Cobra Make, Engine: BDR #888, Keith Craft 408
Originally Posted by mln385 View Post
That is quite an increase no. How do you think it will re act with those rates?
It will be fine. The 450lbs in the front is what the math says you should run for racing. The rear should be right at 900lbs-950lbs. But I wanted a little softer so I went with 650lbs since I drive on the street in addition to autocrossing.
There are no real struts for this setup. The closest is the BDR TD front struts which I bought and a pair of Bilstein rears which I also bought... Otherwise you have to have a special set of one offs made.
Kevin.....
