Thread: Cooling issue
Old 01-10-2015, 10:15 AM
cycleguy55's Avatar
Originally Posted by Large Arbor View Post
If its not the above, I would drain the fluid and change it for starters. I would then look to make sure the fan is operating properly and start with the movement of the air. I run a aluminum FE and on the hottest days it will get to 200, but with the fan on, it never goes above.
Phil
Phil: Are you running a thermostat? 180 degree? 160 degree?
