Old 01-11-2015, 04:41 PM
AL427SBF AL427SBF is offline
Originally Posted by REAL 1 View Post
... As far as my Cobra is concerned it is as pure as it can get short of being an original Yep. Pretty sure about that.
Really, so you meet these specs?
block material Cast Iron
compression 11.5:1
power 305.7 kw / 409.9 bhp @ 5600 rpm
torque 626.39 nm / 462.0 ft lbs @ 2800 rpm
front tires 185x15 Goodyear Blue Dot
rear tires 195x15 Goodyear Blue Dot
front brakes Girling Discs
rear brakes Girling Discs
f suspension Unequal Wishbones w/Coil Spring over Dampers
r suspension Unequal Wishbones w/Coil Spring over Dampers
transmission 4-Speed Top-Loader Manual
gear ratios 2.20:1, 1.66:1, 1.31:1, 1.00:1
final drive 3.54:1
