Old 01-11-2015, 08:48 PM
REAL 1's Avatar
REAL 1 REAL 1 is offline
Banned
Originally Posted by AL427SBF View Post
Really, so you meet these specs?
block material Cast Iron
compression 11.5:1
power 305.7 kw / 409.9 bhp @ 5600 rpm
torque 626.39 nm / 462.0 ft lbs @ 2800 rpm
front tires 185x15 Goodyear Blue Dot
rear tires 195x15 Goodyear Blue Dot
front brakes Girling Discs
rear brakes Girling Discs
f suspension Unequal Wishbones w/Coil Spring over Dampers
r suspension Unequal Wishbones w/Coil Spring over Dampers
transmission 4-Speed Top-Loader Manual
gear ratios 2.20:1, 1.66:1, 1.31:1, 1.00:1
final drive 3.54:1
Yup. Except running Bill Boards front and rear. Also original 427 NASCAR SO's put out around 475 hp. I'm at 502hp. Ops.
