Old 04-19-2002, 05:47 AM
justa6 justa6 is offline
Default DV
I'd like to add a oil thermostat but can't.
Since my motor uses a dry sump system the Pressure out line from the pump has to go to the filter and cooler before the engine gets fed. If I had any restriction (thermostat) then the engine would not get any oil until it "warmed up". It would "warm up" allright
I'm just going to bypass the cooler first and then put a warmer thermostat in also as the engine water temp is also very low.
Thanks for the help its appreciated.
Regards,
Bob
Johnex Cobra, Buick V6
