Old 04-19-2002, 08:09 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb The above cautions on 9 inch posi diffs is why ....
I went with a Strange Engineering (aluminum alloy housing version) "Street Pro" center section (diff) and the "Street Pro" 33 spline axles as well. Both of these components are made for very hard street use, drag racing AND road racing use.
We are using the 9 inch housing out of, I believe, a 1986 T-Bird, painted in black epoxy.
I don't see where a guy has much to lose, especially if he's on a budget, to find a low mileage good condition 9 inch T-Bird (or other) rear, use it till it smokes, then convert to the Strange Engineering stuff. DO be aware that the T-Bird rear is too wide for MOST cobras, the West Coast cobra is a bit wider (like 4 inches)
You can order Strange Engineering gear from www.jegs.com
They also have LOTS of other goodies to drool over !
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
