Old 01-16-2015, 02:51 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by Dimis View Post
That way you could have the best compromise fulfilling all your desires, with scope of having Barry later "upgrade" you to a 482 by using an aluminium pond block and building a short block using most the same parts you used from the 390
Cheap FE, cheap power, authentic looks, and scope for upgrade to what your heart seemingly really desires - a 482 in all aluminium!!!
I'm not an engine builder, but I'd check on this first. I don't think much of anything can be used when you upgrade from the 390/428 (faux FE) architecture to a Pond 427/482 (sideoiler). At the very least, the rings, pistons, heads/valves, rockers, cam, intake and carb would have to be changed. However, everyone will correct me if I'm wrong.
